electric gas pedal in a f-body
Is there any electric gas pedal that will bolt directly into the f-body? Maybe from a GTO, a truck or something? I'm trying to run a LY6 and retain the drive by wire feature. If i have to drill holes for mounting points I will, I just want the drive by wire feature to work in my f-body.
im sure u can make a bracket to bolt one in. i made a bracket to bolt a GTO pedal into my 94 RX7. i just copied the base of the RX7 pedal and made the bracket put the GTO pedal in the same place. im sure u could do the same with the LY6 pedal
