what about an 8.1 or vortec 8100 swap?
Old 04-26-2009, 08:22 AM
vandejr's Avatar
Default what about an 8.1 or vortec 8100 swap?
anyone done or started one of these swaps? i found a longblock relatively cheap low miles full harness ecu and accesories(700). Is it worth the swap or just a ls1 should be ok. I dont care for the weight, just wondering if anyone has ever done one. pics would be cool. i got a 1st gen s10 and a first gen camaro i can stick it in.
Old 04-26-2009, 10:03 AM
Shawn MacAnanny's Avatar
Well the 8.1L uses the BBC platform but doesnt really have a whole lot of aftermarket for them. I dont believe they are compatible with any BBC parts either.
Old 04-26-2009, 10:14 AM
bgblockelcamino's Avatar
the parts for those motors are used in marine applications. so the aftermarket is pretty limited. if i recall it is based on a tall deck block?
Old 04-26-2009, 10:16 AM
vandejr's Avatar
anyone know the hp and tq made by these motors? its going in a daily driver i hate carb.
Old 04-26-2009, 10:23 AM
vandejr's Avatar
found it. 375hp and 490 pounds of tq. not bad.
Old 04-26-2009, 10:35 AM
poconojoe's Avatar
Yea and about 8 miles to the gallon in a 3500 chassis
Old 04-26-2009, 10:40 AM
vandejr's Avatar
in a 3500pound chassis or 3500 chevy hd? if thats in a chassis ill stick to my 5.3 swap.lol.
Old 04-26-2009, 12:39 PM
lsxyj's Avatar
i have one in a crew cab hd 4x4 allison trans it gets 13 mpg on the hwy
Old 04-26-2009, 03:53 PM
poconojoe's Avatar
3500 HD chassis. I'd would wish for 13 MPG, but I don't pay for the gas. And yes it has the allison
Old 04-26-2009, 11:35 PM
busta9876's Avatar
I had a 8100 in my 67 Chevy pickup for a while. TH400, 373 it was always turning some RPM, I probably got about 15 MPG out of it. Probably got better if had an overdrive. 3900 lb pickup.
I recently modified a 8100 harness for a guy putting a 8100 in a wrangler! seems overkill for the jeep, but anyways, here's a picture.
also attached, slightly modifying one valve cover bolt hole, aftermarket valve covers will bolt on, and Summit sells a ARP rocker stud, that will let you run adjustable valve train. M10x1.5 bottom thread, 7/16 top thread. Those are standard BBC 1.7 roller rockers.
I had installed a ZZ502 crate engine camshaft, I was running Megasquirt, with ford EDIS 8 ignition control, so the firing order change did not make a difference to me. Only thing I'd done different was upgrade the valve springs. Stock ones have 89lbs on the seat.
Any mark 5/6 roller camshaft will intall in it, PCM would need programmed for firing order change (I hear this is possible now) Mahle makes a better piston for these engines (pistons seam to be weak spot on these).
Attached Thumbnails what about an 8.1 or vortec 8100 swap?-8100_in_wrangler.jpg   what about an 8.1 or vortec 8100 swap?-hq_8100_1.jpg   what about an 8.1 or vortec 8100 swap?-8100_rockers.jpg   what about an 8.1 or vortec 8100 swap?-8100_side.jpg
Old 04-28-2009, 04:13 PM
topher455's Avatar
Thats alot of weight for that power level. I think it would be easier and more cost effective to use a 6.0. You could get more power and mileage for less money. Unless you are just after the wow factor of the 8.1. Here you go WOW lol.JK.
Old 04-28-2009, 04:43 PM
97ta383's Avatar
does that 8.1 have iron heads? and are the heads designed like ls1 style or just bbc stlye?
Old 04-28-2009, 06:19 PM
topher455's Avatar
They are similar to bbc heads and I think they are cast iron.
Old 04-28-2009, 06:46 PM
busta9876's Avatar
Heads are cast iron, however, will only work with 8100 blocks. The head bolt pattern is different, a few moved around, plus two additional head bolts per head.
They do similar tall intake ports like the lsx, and no water into the intake.
here's picture of an intake port, after my 8100 blew up.
Old 04-28-2009, 11:02 PM
lsxyj's Avatar
the intake ports on the heads r ls style
Old 04-29-2009, 07:57 AM
topher455's Avatar
Yikes. How did that happen?
Old 04-29-2009, 06:32 PM
busta9876's Avatar
too much rpm was likely the cause. The pistons are weak so I hear in these motors. I bought a second 8100 after that one blew up, and when I was going to put it in, I found out it too had suffered the same fate, piston shattered into 1000's of pieces, leaving only the wrist pin still on the rod.
Attached Thumbnails what about an 8.1 or vortec 8100 swap?-dscf0018.jpg   what about an 8.1 or vortec 8100 swap?-dscf0008.jpg
Old 04-30-2009, 03:29 PM
NemeSS's Avatar
last yr. i cam across 2 of em 2 for 1 deal, but i didnt have space for them, in my garage
plus i got a l92 heads engine cheeper anyway.
Old 05-01-2009, 09:55 PM
honda_head's Avatar
hmmm this would be an interesting build to say the least
Old 09-20-2009, 07:45 PM
oregondunerz's Avatar
Not trying to hijack the thread but for anyone interested in going this route I have a 8.1 fresh from the builder and never fired.. Here's the specs:
HEADS
-Exhaust ported and bowls cleaned up
-Went from stock 1.74 exhaust valves to Manley 1.88 stainless
-2.19 intake
BLOCK
-Decked
-Line bored
-Balanced
-Eagle rods
-Stock 4 3/8'' crank
-BHJ balancer
-JE pistons (9:1)
-Comp Cams hydraulic roller w/560's lift
I had it bored out to 502cu! Big cubes, full roller and fuel injection
I planned on putting this in my '65 Chevelle but I've been laid off so the project has been put on hold. I would be willing to sell the engine but I'm keeping the Chevelle.
Quick Reply: what about an 8.1 or vortec 8100 swap?
