11.92 for my Monte SS LS2 on Tues.
Here's the link https://ls1tech.com/forums/drag-raci...gree-heat.html
Thanks guys! I'm running a Vigilante converter with a 2800 stall. Also one thing I might add is I ran with no tricks, the same way I drove it there, no skinnies, almost a full tank of gas. By the end of the rental had about 1/2 tank of gas. Only thing I did was lower the tire pressure on the Mickey's, I didn't even add air to the front tire!
All motor, no spray. The motor is stock untouched since I bought the crate motor 2 years ago. Only typical external bolton's, I'm still even running cats! I don't even have a FAST intake on it yet either, that's sitting in my room waiting to go on. Rear gear is a 3.89 Ford 9". Rear tires size is a 255/50/16, that's the only tire size Mickey Thompson has for the 16" rim.
