Manual to Automatic transmission harness swap.
Old 05-05-2009, 07:11 PM
7firebird1's Avatar
Default Manual to Automatic transmission harness swap.
If I buy a complete harness with pcm, engine and transmission harness that is set up for a six speed...can I change it to an automatic without any major hassle?
Old 05-05-2009, 07:12 PM
7firebird1's Avatar
It is out of an 02' Camaro SS.
Old 05-05-2009, 07:28 PM
the_merv's Avatar
Are you going to convert to an Electronic Transmission?
If so, you would have to go through it and re-pin the PCM Connectors with the proper wires, and get the Connector for the 4L60E.
Old 05-05-2009, 10:40 PM
7firebird1's Avatar
Yeah, I would probably go with a 4l60E. Sounds like a bit more trouble than it's worth. Sounds like I should find a harness for an automatic. Thank's.
Old 05-05-2009, 10:45 PM
RE AND CHERYL's Avatar
If you already have a M6 harness I would sell it and buy a A4 harness. Since everyone wants to swap in a M6 you should have no problem either selling yours an buying what you need or just swapping outright.
Re'
Old 05-06-2009, 08:23 AM
the_merv's Avatar
True..you should be able to find an Auto Harness easily, or even trade for one.
Old 05-06-2009, 09:38 AM
7firebird1's Avatar
I was watching one on ebay while I was posting questions about it. It had the engine harness, transmission harness, pcm and the o2 sensors for a buy it now of $289 and I wasn't sure if I could use it, so I didn't bid. Someone else got it before I could. lol. But at least now I know. Thank's for everyones help.
