What length of drice shaft.
Old 05-07-2009, 02:30 PM
Camaro Ken's Avatar
Default What length of drice shaft.
Car is in my sig. Edelbrock engine mount plates. What length do I need to cut my driveshaft to?
Old 05-07-2009, 02:39 PM
stealth71's Avatar
Best bet is to get out the tape and measure. I hope you're planning on having a shop do it so it can be balanced properly.
Fill this out and take it with you: http://www.dennysdriveshaft.com/how_to_measure.html
Old 05-07-2009, 03:33 PM
topher455's Avatar
Alot of shops have you measure differently so call the shop you plan to use and ask how they want you to measure. If you use dennys obviously they have a form to fill out. I prefer to use local guys so if there is an issue I can drop it off and have it fixed. FWIW
Old 05-07-2009, 08:42 PM
Shawn MacAnanny's Avatar
remember you need a pinion angle of 3-5 degrees and you must mesure with the rear end jacked up (springs loaded). Mine was 48" dead on and i bough tit from Dennys driveshaft. My nitrous read one was only $450 and its got a lifetime warranty with free lifetime upgrades.
Old 05-07-2009, 09:22 PM
clm69z28's Avatar
I posted a question about this same issue with the Edelbrock kit but they ddidn't answer. I thought this was supposed to locate the LS1 within a half iinch of the old motor location so things like the driveshaft, crossmember, linkage etc. wouldn't need to be modified. My driveshaft is at least two inches too long in my Chevelle/LS1/4l60 setup.
Old 05-08-2009, 07:54 AM
topher455's Avatar
I usually measure with the car on the ground. No surprises that way. Weight dist will mess with height while a car is on a jack.
Old 05-08-2009, 08:01 AM
zman1969's Avatar
when its custom you have to (and always should) measure yourself !
Old 05-08-2009, 12:06 PM
Camaro Ken's Avatar
Thanks for the input guys. Any more will be appreciated but i get the point.
Old 05-09-2009, 04:04 PM
fast400's Avatar
Denny's is the way to go! You can't screw it up if you follow their sheet. Super helpful folks too!
Old 05-09-2009, 06:44 PM
cherryelky305's Avatar
I got mine through denny's I had no problems what so ever, they have great customer service.
