Inline fuel pumps
Old 05-10-2009, 01:28 PM
sandking's Avatar
Default Inline fuel pumps
Just curious what inline pumps most of you are using on your conversions. My last conversion I used the Aeromotive A1000 pump, but this time I think that pump is way overkill for a 5.3 with a cam only truck engine. What are some of the fuel set ups you guys are using?
Old 05-10-2009, 02:23 PM
LS1MCSS's Avatar
I put a Mallory Comp 250 on mine and it makes so damn much noise that I will probably change it. I can't stand this damn thing.
Old 05-10-2009, 02:30 PM
sandking's Avatar
Well, dont use the A1000 pump if you dont like the noise How are the Holley pumps?
Old 05-10-2009, 02:47 PM
Shawn MacAnanny's Avatar
Ill be ordering a walbro 255 for mine with a corvette filter and regulator. Pump is about $120, filter and regulator is like $40. Im running 3/8" hard line with a 5/16" return line and i'll be using all brass compression fittings.
Old 05-10-2009, 02:54 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I took the intank pump out and I'm using a Holley Black electric pump. I've also got two Holley regulators; one for the motor side and one for the nitrous side.
The Holley Black is noisy too
Old 05-10-2009, 02:56 PM
Are are you running a carb setup? I ran a holley red 97GPH all last summer with my setup. No issues and my engine was around 500hp.
Old 05-10-2009, 04:18 PM
LS1GMCTruck's Avatar
So whats the quietest in-line pump out there?
Old 05-10-2009, 05:18 PM
Z28/2002's Avatar
Yeah I've got a carb setup
Old 05-10-2009, 06:37 PM
LS1MCSS's Avatar
I have a Weldon that I used on my injected motor. It's real quite and after some research, I find that it can also be used for a carbed engine. It can be regulated down to the correct pressure. I will be switching to it shortly. If you watch the video I posted, you can hear the Mallory pump come on just before the car starts.
Old 05-10-2009, 09:34 PM
Hotrod406's Avatar
I'm using a Bosch 044 pump. It will support a lot of power and is relatively quiet. The threads on it are straight metric so finding fittings is kind of a pain.
Old 07-26-2009, 07:53 PM
BlackTA96's Avatar
Kinda back from the dead, but....
I'm gonna be running a ls1 with a ms4 on a 150 shot.
You guys think a inline walbro 255 will be enough?
Old 07-27-2009, 12:19 PM
BlackTA96's Avatar
anyone???
Quick Reply: Inline fuel pumps
