cam only carb'd setup with 6010 box
Old 05-13-2009, 10:13 PM
xpndbl3's Avatar
Default cam only carb'd setup with 6010 box
what's your total timing that you figured out at the track?
i have a cam only, vic jr, 4150 setup. what was your total timing after adjusting for best mph. I'm at 28 degrees on premium, just trying to see how much higher I should be shooting for next time out. Trying to get in the ballpark for pinks all out instead of paying for a dyno tune if I don't have enough time off work beforehand.
Old 05-14-2009, 01:03 AM
Roller406Bu's Avatar
i was running 32 total....went up to 36 and picked up 2 tenths and 1.5 mph...
Old 05-14-2009, 07:20 AM
xpndbl3's Avatar
so now you're at 36 total? Guess I have a lot more in this combo afterall
Old 05-14-2009, 10:23 AM
tennerv8's Avatar
I have heard the carb'd ls's like more timing.
Old 05-14-2009, 01:35 PM
xpndbl3's Avatar
well i'll have to get it to the track one more time shortly or hit up a dyno it's looking like.
Old 05-14-2009, 02:09 PM
81 Camaroman's Avatar
36 degrees is alot more than an efi motor my buddy is running 271/2 degress with cam heads and fast intake
Old 05-14-2009, 05:11 PM
Shawn MacAnanny's Avatar
Carbs have colder fuel and IATs so they can take a little more timing but i only ran mine to about 32 degrees.
Old 05-15-2009, 01:48 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've gotta upgrade to this box one of these days. I'm still running the pill style on my car and have no idea what the timing is at. I've got the "Curve 6" in it and I'm running PRC heads, MS3 and a 150 shot
Old 05-15-2009, 07:16 AM
SMAX's Avatar
If you are running the edelbrock box isn't that pill 36*? Seems like way too much timing on a 150hp shot.
Old 05-15-2009, 07:20 AM
butler's Avatar
msd box has two power wires one pulls up to 10 degrees timing for nitros when enabled and the second has a two step. I have the msd box which you can tune your advance and add vacuum advance to it. Pulled pcm out and am awaiting motor parts.
Old 05-15-2009, 10:00 AM
Z28/2002's Avatar
I don't have the slighest idea what the pills are. If anyone knows shoot me a PM
The car didn't run too bad on a 125 shot with that pill in it.
Old 05-15-2009, 12:39 PM
NemeSS's Avatar
iirc u can look up the timing degrees for each pill, i oroignally used the edelbrock box also and i think the stock engine pill was 25 degrees iirc.
the manual i had listed the timing ranges for each pill, but who knows where i the hell i lost it.
Old 05-15-2009, 12:40 PM
SMAX's Avatar
pill #6
0 rpm-22*
800 rpm-32*
4500 rpm-32*
6700 rpm-36*
6800 rpm-36*
6900 rpm-36*
Seems like a lot of timing and you aren't even able to pull any for the nitrous with that box. You should probably upgrade to the msd 6010.
Old 05-15-2009, 03:09 PM
Z28/2002's Avatar
wonder how the car would run with one of the other pills in it. It'll be a while before I got the cash again to upgrade to the 6010
Old 05-15-2009, 04:39 PM
I'm pulling 8 degrees out on mine to be safe on a 150...
Old 05-16-2009, 01:25 AM
billyflantos's Avatar
you're right on the money,taking 6 to 8 degree's out.....maybe go a step colder on the plug and gap them .028....
Old 05-16-2009, 09:30 AM
Z28/2002's Avatar
I'm running the TR6s gapped at .038. I'll see how it runs with the other pills when I get back to the states
Old 05-16-2009, 09:45 AM
not trying to knock your set up,but if you're running a carb and a msd box shorten your gap up it will help.....and thank you for serving and protecting our country.....
Old 05-16-2009, 01:38 PM
Z28/2002's Avatar
no it's cool, any help I can get to make it run a little better. what do you think I should gap them at?
No Problem
Old 05-16-2009, 11:26 PM
.028 to .030 is what i run them at...
Quick Reply: cam only carb'd setup with 6010 box
