Where can I get 1 7/8" Primary Header Flanges?
Old 05-20-2009, 09:43 PM
ryclef331's Avatar
Default Where can I get 1 7/8" Primary Header Flanges?
Just like the title says! I've got a set of accufab 1 7/8" Primary Mid Length 351 swap headers coming for my mustang swap and I need to know where to pick up some flanges for that sized primary tube.
Old 05-20-2009, 10:41 PM
$O$OE's Avatar
http://www.sdparts.com/
Old 05-21-2009, 12:26 AM
ryclef331's Avatar
thanks but they aren't 1 7/8" When I searched, the GMPP's were only 1 3/4"
Old 05-21-2009, 09:49 PM
Hotrod406's Avatar
Lingenfelter makes some in stainless for a decent price. Look for them on ebay.
Old 05-23-2009, 02:59 PM
Closed ex-Sponsor Account
Tom@ARH's Avatar
Give us a call we have them in stock
Old 01-04-2010, 06:57 PM
TJ
TJ's Avatar
what is the cost for a pair?
can you use stock gm gasket with larger tube, or will you need an aftermarket gasket?
thank you.
Old 01-17-2010, 10:56 AM
jeejee's Avatar
interested too in the price..
Old 01-17-2010, 11:45 AM
TJ
TJ's Avatar
jegs has them cheaper than anywhere, but they are mild steel, 2" opening. gives you a lil room to move the tube around for spark plug clearance and what not.
they are 39 each.
cheapest stainless ones i found where on ebay from LPE.
Old 01-17-2010, 07:03 PM
xpndbl3's Avatar
TJ got a part number for those jegs ones?
Old 01-17-2010, 08:04 PM
Qwiknotch's Avatar
I got mine from Cone Engineering...
http://www.coneeng.com/
they are in Los Alamitos and have every damn size you want...
Old 01-17-2010, 08:19 PM
TJ
TJ's Avatar
i cant get the page to link.
555-31803 is the part #.
i got a lick on a set of stainless 1 7/8 stainless, tig welded headers from jessie coulter from the horsepower house in bowling green.
he is building a new set, and i ran across a link to his site at just the right time.
slide in from top and bottom, with the starter bolted up!
good luck on your project.
Old 01-17-2010, 09:49 PM
xpndbl3's Avatar
i don't want to know what he wants for those
I'll probably just buy the flanges and do up some 1 7/8" ones shortly. Just deciding if I want to motor plate the car so I have more freedom with running pipes since I've only built 6 or so headers and can't build to my visions just yet compared to shops that want $1500 for set.
Old 01-17-2010, 10:33 PM
TJ
TJ's Avatar
i got them for 700. id have more than that in a mild steel set if i paid someone to build them.
was looking at 600+materials.
i couldnt be happier.
sold my hawks headers too so it all worked out.
post up some pics when you start hacking on them.
Quick Reply: Where can I get 1 7/8" Primary Header Flanges?
