how to bleed clutch?
Old 05-31-2009, 04:22 PM
xyster's Avatar
Default how to bleed clutch?
how do you bleed the clutch on a 2000 LS1 T56?
Old 05-31-2009, 04:51 PM
Cam72aro's Avatar
Fill the resovoir with fluid, put the cap on. With the bleeder on the slave closed, get someone to push and hold the clutch pedal to the floor. Then crack the bleeder open then close. Do the 4 or five times then fill the resovoir back up. Makr sure that it doesnt go empty. Feel the pedal and see if it feels ok or is mushy. Repeat till you have a smooth good feeling pedal.
Old 05-31-2009, 08:05 PM
xyster's Avatar
I know how to bleed it but where is the bleeder valve located?
Old 05-31-2009, 08:33 PM
lss1's Avatar
Hmmmmmm???????????? The bleeder is on the slave cylinder located on the firewall.
Old 05-31-2009, 08:55 PM
xyster's Avatar
oh sorry this is a swap and i guess i dont have that part i am going to be using a Wilwood master cylinder with a Henson line most likley so then what?
Old 06-01-2009, 08:01 AM
Cam72aro's Avatar
Wrong. The bleeder is on the slave which is in the bellhousing of the trans. The bleeder screw comes through by the inlet line into the slave cylinder. Its a 11mm hex if I remember correctly.
Old 06-01-2009, 06:55 PM
Nissan LS240's Avatar
you have too options bleed manually by pumping clutch a couple of times hold it too the floor while somebody cracks the bleeder that's on the slave cylinder, that in the bellhousing(just above where clutch line goes into bellhousing there should be a opening where the bleeder screw is located, or you can find someone with a pressure or vacuum bleeder that makes it so much easier.
If your replacing the master cylinder make sure you bench bleed master cylinder makes it easier to bleed system.
Old 06-02-2009, 07:59 AM
crainholio's Avatar
Step away from the keyboard.
Quick Reply: how to bleed clutch?
