Lean condition at wot
93 lightning w/ 03 dbw lq4 4l80, harness was modified by current performance and is out of a 03 express 2500, computer is out of an 03 silverado 2500hd
when computer was tuned he turned vats and emissions off, and turned the electric fans on, but did not mess with anything else
walbro 222lph inline fuel pump 60# fuel pressure at wot
I tried to list as much info as possible
the check engine light does not come on either to show a lean condition
the truck drives great just cruising( maybe a little lean) wideband jumps between 15.0-15.5
when you are stopped and go full throttle the wideband will stay around 15.0, but as soon as it shifts to 2nd gear the afr wil drop to around 13.5 and stays there
if you are cruising on the interstate and go wot te same thing happens, the truck will downshift to 2nd gear and afr wil be around 15.0, then as soon as it shifts to the next gear the afr will drop to around 13.5.
has anyone run into a problem like this before? any ideas?
