exhaust question for ls1 swap - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 07-01-2009, 05:37 PM   #1
Default exhaust question for ls1 swap
I am working on putting an exhaust into my 79 trans am which currently has a 400 pontiac in it. In the future i am planning on putting a 5.3 or other lsx into it. The system that i am going to put in is a 2.5 inch dual exhaust that is mandrel bent. When i do the lsx swap i will in all likelyhood have to take the exhaust apart again to put in the o2 sensors also i will need to take it apart to move the x back when I swap in the longer t-56.
What is the best way to put the system in so that I can take it apart at a later date.
the 2.5 inch system should be good enough right?
how much does a t-56 weigh?
would band clamps make the taking apart easier later?
can i weld o2 sensor bungs in at a later date or should i buy collectors that have the bungs in them?
thanks for the help!
79inpa is offline   Reply With Quote
Tags
conversion, exhaust, ls1, o2, placement, sensor, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
