Running an LQ4 without o2 and maf?
Old 07-06-2009, 07:05 PM
WVUSierraC3's Avatar
Default Running an LQ4 without o2 and maf?
I have been looking at my harness lately and can't find the plugs for my O2 sensors and my MAF, is it possible to run these motors with a basic program and not use these sensors?
Thanks
Tom
Old 07-06-2009, 07:07 PM
cdwood388's Avatar
I have heard of them being run without the MAF and just the o2 sensors but never without both but I don't know maybe. If it were carbureted then yea but I wouldn't think it could be done with fuel injection
Old 07-06-2009, 08:54 PM
6.0Nova?'s Avatar
If I understand GM's open-loop and "limp-home" strategies well enough, you should be able to get by without both, since it should default to the MAP and preset fuel tables, but I dunno why you'd do without oxygen sensors in a system like this? or no MAP without an SD-only tune? I mean I could forsee it it you just wanted to get things started, but...
Old 07-07-2009, 01:46 AM
brianfromhawaii's Avatar
I just did a ls1 conversion into a 91 camaro and it has ZERO 02 sensors. NONE. and never will have any besides a wide band while im tuning it.
Old 07-07-2009, 05:25 AM
Pop N Wood's Avatar
Try disconnecting the MAF from your daily driver and see how far you go.
Beyond that do a search on speed density tunes.
Old 07-07-2009, 09:21 AM
ls1nova71's Avatar
Hell, you can take a piston out and still make it run, but why would you want to? I ran my LS1 in my '33 without a maf when starting it for the first time, and several times after that, but it fouled the plugs in short order and then wouldn't even run. Just my experience.
Old 07-07-2009, 02:05 PM
gotta love the ball bustin
thanks for all the answers i guess I'm gonna have to get another harness or carb it
Old 07-11-2009, 10:28 AM
muncie21's Avatar
You can run without the MAF and O2s....it's called open loop speed density. If you are confident in your tuning abilities you can make a OLSD car run fine.
Personally, from an engine safety perspective, I would run Closed Loop SD if you are set on running without a MAF.
Old 07-11-2009, 11:05 AM
chevellepowered's Avatar
Originally Posted by muncie21
You can run without the MAF and O2s....it's called open loop speed density. If you are confident in your tuning abilities you can make a OLSD car run fine..
exactly,,, i m running my 5.3 in my chevelle with niether one of them, temperarly.. spark plugs look perfect to me,.. i'll be running wideband.. i recondmend on getting one if ur tuning urself..
Old 07-12-2009, 08:16 AM
Shawn MacAnanny's Avatar
I'm not running with a MAF, im using O2s though. Not having a MAF doesnt really matter. Unplug the MAF on your LT1 or LS1 and drive without it, i didnt even lose 1mpg with it unhooked in my LT1.
Old 07-12-2009, 08:23 AM
13 Second Truck Club
726.0chevelle's Avatar
ive been running my lq4 without a maf but only due to me accidently backing over it lol time to check the classifieds
Old 07-12-2009, 08:30 AM
Lol i have a Z06 Maf from an 01 i believe i'll sell you for 40 shipped. Its the de-screened version. I've had it laying around for ever.
Old 07-12-2009, 08:43 AM
is it a 5 pin like a truck
Quick Reply: Running an LQ4 without o2 and maf?
