Will a T5 work on a LM7?
yes. there are a few running around here. By yes, I'm referring to TKO5-600's.
I can't remember everypart that is required but a quick search should help you out.
You can use the keisler tranny bellhousing to mate the t5...can't remember the rest!
the T5 problem usually wont get wrecked from the performance of the engine but from the loose nut with his hand on the shifter even with an aftermarket shifter they are suseptable to burred syncronizers and front main shaft bearing failure since 3rd is an unsupported gear. I personally have destroyed a total of 11 BW T5 trannys and 4 of which were within a one month period. Lots of Fun
just curious. not planning to beat on the car. just to drive around and the lm7 was just gonna be pretty much stock with a ls1 manifold. so itll maybe be around 300hp or so. im not sure on what it would make.
