DBW costs
Old 07-21-2009, 09:46 PM
CharlieC's Avatar
Default DBW costs
Looking to add a DBW pedal-TB setup to my LSX-based '57 Chevy. What's the average boneyard cost for a pedal/wiring and TAC? First quote I got was $500 which sounds pretty excessive.
Thanks,
Charlie
Old 07-21-2009, 10:22 PM
dpd069's Avatar
I paid $95 at my door for a PCM, TAC and harness from a junkyard called Carguts in Tenn. It was out of a 2003 Suburban
Try this link and look for 'electronic box' for the year and model you'd like to have-
www.car-parts.com
Sort the result by lowest price and start calling. Look for a yard that has all the components together off the same vehicle that will make you a package deal.
Good luck
Old 07-21-2009, 11:49 PM
CharlieC's Avatar
Does the wiring harness for the pedal go... pedal to TAC to TB? I'm not using an LSx PCM and harness, so hoping the above is correct.
Thanks,
Charlie
Old 07-22-2009, 05:20 AM
poconojoe's Avatar
Thanks,
Charlie
It goes pedal to TAC to PCM. The PCM controlls the throttle body. The TAC talks to the PCM on special dual serial communications circuit
Old 07-22-2009, 10:56 AM
dpd069's Avatar
Just a little clarification to poconojoe's note-
The engine harness has a connection to the TAC.
The TAC has its own small harness to the pedal assembly inside the car.
The TAC to pedal harness (I guess it would be better called a jumper) has a grommett on it for going through the firewall. It is about 18-24" long
Old 07-22-2009, 12:09 PM
CharlieC's Avatar
Hmm, since I'm using BigStuff3 for my EFI controller, sounds like I'm SOL on using a DBW TB. Correct? I thought the TB was controlled by the pedal, and the TAC was just an interface between the two.
Charlie
Old 07-22-2009, 01:40 PM
dpd069's Avatar
The throttle body is controlled off of a driver in the GM PCM, and not all PCMs have the driver circuit installed.
I don't know what a 'BigStuff3' is. Is it a standalone like a FAST or Motronic, or a variation of a GM PCM?
I would think you'd have to talk to the manufacturer to see if it was compatable with a DBW.
With the GM PCM being so tunable, supported and cheap, what made you decide to use the 'BigStuff3'? Just curious.
Old 07-22-2009, 04:56 PM
CharlieC's Avatar
http://www.bigstuff3.com/ In the hands of the right person (that doesn't mean me...) it's probably the best EFI setup out there. I got a great deal on it, which was about the same as a PCM/Engine Harness and (1) mail order tune, so I figure I'm ahead with it.
Looks like I'll be sticking with my cable TB...
Charlie
Old 07-22-2009, 06:00 PM
dpd069's Avatar
Well, I didn't have any trouble selling the DBW setup that wasn't correct for my engine.
Post it up on this website and it will go quick.
Quick Reply: DBW costs
