Where can I find a 98 ls1 fbody engine harness schematic?
Old 07-23-2009, 05:20 PM
formula17's Avatar
Default Where can I find a 98 ls1 fbody engine harness schematic?
I believe there is a difference between 98 and 99-02 engine harnesses as far has how they connect in the car under the dash on an Fbody. I need to know if anyone has a breakdown of the engine harness as to what wire goes where. I am putting an ls1 in my 93 firebird using a 98 harness. There is I know a really good write up on here about doing this, but its with a 99-02 harness.
Thanks,
Nick
Old 07-23-2009, 06:43 PM
dpd069's Avatar
Autozone has some nice schematics you can download for free from thier website.
Old 07-23-2009, 07:31 PM
the_merv's Avatar
The 1998 is more user-friendly since it uses the Analog Gauges that are in your 1993, all the required signals you need are in the Harness.
If I can get my All-data working I can get you a Pin Diagram.
Make sure you get the 1998 LS1 Temp Sensor..part # 12551708.
Old 07-23-2009, 08:31 PM
jomomma's Avatar
i have the pin out sheet for a 98. i can fax it.
Old 07-23-2009, 09:01 PM
aknovaman's Avatar
PM me with your email address and I'll send them to you in PDF and excel format.
Anthony
Old 07-24-2009, 07:42 AM
formula17's Avatar
Email is ngdformula17@hotmail.com
Fax is 586 777 4293
Thanks guys for the help,
Nick
Old 07-24-2009, 09:07 PM
aknovaman's Avatar
Check your email for attached 1998 LS1 Camaro schematics.
Quick Reply: Where can I find a 98 ls1 fbody engine harness schematic?
