GTO vs. F-Body compressors.
Old 07-27-2009, 02:31 PM
jeeperanthony's Avatar
Default GTO vs. F-Body compressors.
Anyone know if the GTO compressor will fit on the f body bracket or vice versa?
The compressor on my swap hits the headers I got, and I want to know if they will interchange.
Old 07-27-2009, 04:05 PM
John McGraw's Avatar
If I remember correctly, the only difference is in the diameter of the compressor and where the lines enter the compressor. You can also cut the mounting bracket down a little to move the compressor closer to the block. The legs that mount to the block can be trimmed down quite a bit and the angled brace across the rear of the bracket can be removed completely. The GTO compressor is slightly smaller in diameter and the lines enter the side of the case instead of the rear.
Regards, John McGraw
Old 07-27-2009, 06:27 PM
downset71's Avatar
i still have my 04 GTO compresser and brackets. never used on my swap, as i went with a Classic Auto Air setup.....less than 20k miles when pulled....
