trk manifold w/thumper cam LQ4
Old 07-27-2009, 09:45 PM
flywheel's Avatar
Default trk manifold w/thumper cam LQ4
Going into a 71 chevelle w/ 4l80e combo. I realize that the trk intake runs out about 5500 rpm, Question is, will the comp cams thumper cam be a good fit for the lq4/auto. This is for a cruise/car show car NOT a race car. Im not lookin for the top notch in performance BUT again I don't want a dog either. I want this car to "sound" like a muscle car and run respectivly. I would like any input ideas.... Ive read and read about this AND used the search function also..
Rick
Old 07-27-2009, 10:46 PM
djsanchez2's Avatar
How bout a hot cam? They are not too much larger than a LS6 cam, make decent power and sound wicked with a nice exhaust. You can also have the truck intake ported to extend your upper rpm limit.
I thought the thumpr cams were designed for carbed motors? Which one were you looking at?
Old 07-28-2009, 11:45 AM
Bo185's Avatar
You could also get the 90mm LS2 trailblazer SS intake they come up on e-bay now and then and flow better above 5500 then the smaller truck intake.
Old 07-28-2009, 01:04 PM
bczee's Avatar
As long as your not trying to keep and go too deep into the throttle, You should be ok... get a good tune... but as you already know.. RPM range is limited on the upper end. but those Truck intake to make a great low end torque monster.
But there are other manifold (LS1 are cheap, LS6 are the best bang for the buck)..
if you can cover up the truck intake.. these are not the best looking intake..
Old 07-29-2009, 10:21 PM
flywheel's Avatar
The comp cam thumper has more lift than the Hot cam and a 109 vs 110 lobe sep. so I thought it would be better... More thoughts?
Rick
Old 07-29-2009, 10:24 PM
flywheel's Avatar
Correction, the hot cam is 112 lobe sep....
Old 07-30-2009, 12:38 PM
NemeSS's Avatar
the truck 90 mm intake will be a good addition and can use 90mm tb and is kind of like the ls6 version of the truck intakes.
i would go with a milled stock heads, thinner gaskets, and a LPE GT11 cam. for that excellent throttle response and of course uncapped exhaust will make even the stock cam sound like a muscle car. so put a c/o in your 3in. exhaust.
Old 08-02-2009, 10:32 PM
flywheel's Avatar
I wasn't wanting to change the manifold, $$ if I did, I'd just get the LS6 one.
I was wanting a cam to compliment the manifold...? anymore thoughts????
Rick
Old 08-03-2009, 12:00 PM
71 chevelle's Avatar
I would also like to hear more feedback. I will be running a lq4 w 4l60e and a ported ls2 intake. I is my first choice in a cam. part number 54-600-11
Old 08-05-2009, 10:39 PM
Hey fly I called TR today and said the best cam for the 6.0 is the mother thumper cam # 54-601-11. John over at TR has this cam for $599 with the comp cams springs # 26918-16 and the tr 7.4 pushrods. This would be all you need to make sure you have no issues with the swap. I am sure if you wanted to you can change the timing chain , retainers, rockers, lifters, and valve locks, but that just means more $$$$
Old 08-07-2009, 09:55 PM
lsxmalibu's Avatar
looking at my dyno sheets, my truck intake and 75mm throttle body pulls fine to 6000 , doesnt drop off, just stays flat then.
Old 08-07-2009, 10:30 PM
flywheel's Avatar
Thanks guys.
LSX, what size nos do u use?
71 chevelle, I tried twice to get ahold of TR, left 2 messages w/ no answers. So they liked the "mother" thumper cam? Any reason why?
Rick
Old 08-07-2009, 11:00 PM
Jeff Smith's Avatar
This post is great information..I would like to see the dyno. result >between Ls1 intake and truck Intake..
I do have lq4 engine and 4l80 trans of 2004 GM Truck.
Old 08-07-2009, 11:42 PM
fly, the thumper cam was made for the 4.8l 5.3l 5.7l the mother thumper was for the 6.0l or a built 5.3l
you can find the build for the motor here. I will posting pics of everything as I go along.
https://ls1tech.com/forums/conversio...-manifold.html
Old 08-08-2009, 07:48 AM
lsxmalibu's Avatar
Originally Posted by flywheel
Thanks guys.
Rick
With the Zex system I had, I could jet up or down and it was 100 rwhp, hopefully the Brand X will be higher.
Old 08-08-2009, 07:52 AM
lsxmalibu's Avatar
your not going to gain anything with a ls1 intake over a truck intake
http://www.performancetrucks.net/for...d.php?t=397720
Old 08-08-2009, 11:06 AM
tennerv8's Avatar
Thats funny that the truck intake flows that well. Or that the LS1 intake flows that poorly.
Old 08-08-2009, 11:39 AM
Ls1 has the high end gain and the truck has it in the low end. Our heavy cars need the low end hp/tq. That is why I when with a ported ls2 intake. Their is several threads on how a ported ls2 will have a gain of 5-7 hp over a stock fast intake.
Old 08-08-2009, 07:45 PM
NemeSS's Avatar
they flow about equal, the ls6 is the best flowing of them all.
oe wise
Quick Reply: trk manifold w/thumper cam LQ4
