1994 RX7 5.3 swap
Old 08-02-2009, 06:49 PM
PETE180's Avatar
Default 1994 RX7 5.3 swap
Been working on it a year now, time is scarce and when you want it your way it seems it takes much longer. 57,xxx miles original 5 speed car. I'm using the Hinson swap kit. Here's the parts so far:
1. 2004 LM4(aluminum 5.3L), 50K miles
2. Patriot cnc'd and milled 5.3 heads .028 gasket
3. Lunati 222/230 114+4 cam
4. Stock manifolds for now
5. LS1 intake(figured if it's decent on LS1's with 23 less cubic inches it should do the job).
6. Aeromotive fuel system(a1000 pump and regulator, braided lines,etc.)
7. 1998 ls1 ecm and harness(vats removed, setup for 5.3/6 speed with stock ls1 injectors)
8. Spec clutch, stock flywheel
9. Ron Davis radiator with Taurus fan
Attached Thumbnails 1994 RX7 5.3 swap-rx7-044.jpg   1994 RX7 5.3 swap-rx7-049.jpg   1994 RX7 5.3 swap-rx7-050.jpg   1994 RX7 5.3 swap-rx7-052.jpg   1994 RX7 5.3 swap-rx7-053.jpg
Old 08-17-2009, 01:30 PM
v8envy's Avatar
nice project I am building a silver fd with L33 5.3 (aluminum) w t56 as well, I am about to order a samberg kit, I have been sourcing parts on here for a while now. any idea what kind of power your making? I am debating since I don't have the motor in yet I may put a cam in!
Old 08-17-2009, 01:41 PM
overkill-lt1's Avatar
i have a rx7 swap as well. its nice since our cars weigh about 800 less than a firebird or camaro. i have about 400 hp on mine with just a cam and some bolt ons after it was tuned properly
Old 09-01-2009, 07:27 PM
v8envy's Avatar
I hope I make 400 with just a cam swap
Old 09-01-2009, 09:38 PM
Phoenix 5.7's Avatar
looks like it came out well. im working on a 94 LS2 setup w/ samberg mounting/rad
Quick Reply: 1994 RX7 5.3 swap
