keeping factory gauges options? 72 chevelle ss 4160E
Old 08-04-2009, 05:41 PM
7deuce-ss's Avatar
Default keeping factory gauges options? 72 chevelle ss 4160E
i was looking through the forums and have heard about Abbott Cable X but some say its the not best. also heard About different tail shafts to convert to cable and the vss sensor both.
anyone got pictures or a place tha sells some of these setups?
we have the trany torn apart at the moment and thinking of some conversion before we put it together..
thanks!
gabriel
Old 08-04-2009, 06:51 PM
ls1nova71's Avatar
Street and Performance sells a kit to change the tailshaft, but it's over $500. It's on page 105 of their online catalogue. I've been using a cable x for years and it seems to work good.
http://www.hotrodlane.cc/08%20catalo...talogMAIN.html
Old 08-04-2009, 09:58 PM
builder1's Avatar
I have the cable x and bought it through ebay i believe straight through them. It is the 30 slot box that helps with it being erratic and it works perfect. I also wanted to keep my stock gauges
Old 08-05-2009, 12:23 AM
7deuce-ss's Avatar
so you guys havent had any problems with it? is it pretty much in the ballpark on the speed?
ya iam trying to do all i can to save the factory guages and use them, i dont want to mod the dash being it is a ss.
any pics?
any other options out there?
thanks guys this is a big help!
gabriel
Old 08-05-2009, 09:48 AM
builder1's Avatar
I have not had any problems but i have a 30 slot unit. When you buy one make sure you ask for the 30 slot. It make the speedo smoother. You have to program the unit with all your ratios to get it to read the correct speed. If you have any questions they are good with giving you the answers. Also when you wire it you have to go to the speed sensor off the trans not through the computer. Simple 3 wire hook up
Old 08-05-2009, 10:03 AM
Shon Herron's Avatar
cableX: does the 30 slot unit work below 30MPH, ie the needle doesnt jump from 0-30MPH? I have been following another thread and that is the issue they report.
and where do you have the box mounted? I am going to need something soon so I am in research mode.
Old 08-05-2009, 07:02 PM
builder1's Avatar
The 30 slot unit cures that problem. I addressed that problem before i bought it and they recomended the 30 slot unit. I have no problems with mine, very smooth and accurate.
Old 08-06-2009, 12:47 AM
7deuce-ss's Avatar
nice! i have not seen that one yet, so is the box bigger being that you have to program it? so it runs off power and ground then signal off the vss?
Quick Reply: keeping factory gauges options? 72 chevelle ss 4160E
