LS3 in a 1969 camaro Vac Lines
Old 08-09-2009, 01:01 PM
blownox13's Avatar
Default LS3 in a 1969 camaro Vac Lines
Ok my build is going in my 69 camaro. 6.0 block, l92 heads, LS3 intake, 40lb injectors, 90mm drive by wire throttle body, custom cam. I need help with the two Vacuum holes in the valve covers and two lines off of the front intake. Where do they hook up at? Anyone have any pics of theirs? One line off the front left side of the intake should go to line in the knock sensor cover, but mine block is out of a truck so I don't have aline in my knock sensor cover area. HELP anyone
