Preparing to order my radiator, anything special I need to account for?
Old 08-10-2009, 07:27 PM
1936 LS1's Avatar
Default Preparing to order my radiator, anything special I need to account for?
Pretty sure I'm gonna order a custom PRC aluminum radiator for the '36. Other than the obvious hose inlet/outlet locations is there anything particular to the LS motors that I shoud account for?
Old 08-10-2009, 07:33 PM
Stu Cool's Avatar
If I was having a radiator done from scratch I would have them add a 1/4" bung just below the main inlet for the steam relief connection. If possible I would also do a double pass cross flow radiator with both the inlet on and the outlet on the passenger side since that is where the connections are on the motor. That may no be possible on your narrow car.
Pat
Old 08-10-2009, 08:28 PM
kwhizz's Avatar
Just got my PRC a couple of weeks ago.....A.C. Condensor, Steam Vent Bung, Both fittings on the passenger side, Shroud and Fan.......Quality piece
Ken
Old 08-10-2009, 08:39 PM
matysik27's Avatar
^^that is a really nice looking peice right there. High quality!
Old 08-10-2009, 08:48 PM
1936 LS1's Avatar
Pat
That's exactly the sort of input I was looking for. Thank You!
Old 08-10-2009, 08:49 PM
1936 LS1's Avatar
Ken (kwhizz), Do you have your radiator hoses connected yet? If so, any pics from that side?
Old 08-10-2009, 08:56 PM
52 Rat's Avatar
Pat
Guys, what is the steam relief connection? Here is a pic of my LQ4. Does it have the steam relief? Sorry to be so vague, this is still a little new to me.
Preparing to order my radiator, anything special I need to account for?-100_1577.jpg
Old 08-10-2009, 09:07 PM
knievel's Avatar
Attachment 191980
Front of the drivers side head. All 4 points (2 on each head) are connected with tubing (under the intake) to release air pockets from trhe upper head water jackets.
This needs to be tied into the pressure side of the system
Old 08-11-2009, 07:05 AM
kwhizz's Avatar
This is the only Pic I have right now........Fitting the front sheetmetal right now to get the Radiator placement where it needs to be.......I'll take some more pic's when the opportunity is right........
Ken
Old 08-11-2009, 10:05 AM
Oscar Will's Avatar
Nice radiator!!!! That should do the job well. There is no such thing as "too much" radiator.
We ran mine through Needles, CA last month in 120 degree heat with the air conditioning on.....the LS1 never went above 195 degrees!!
