LS6 Intake manifold and cable TB on LS2 with E40 PCM
Is there any way to make this work with the E40 and stay cable TB?
I have asked around to several tuners and everyone says either go DBW from a C5 Vette or get a E38 PCM.
I'm also wondering if the sensors in the LS6 intake manifold are compatible with the E40.
I just bought a E40 and now I'm feeling like I made a mistake... *kicks dirt*
T.I.A
-A
T.I.A
-A
9 Second Club/LS1TECH Sponsor
Short answer: no.
E40 is for 24X reluctor, 1X cam, electronic throttle.
E38 is for 58X reluctor, 4X cam, electronic throttle.
If you have a 24X engine, at least you can drop back to an LS1 style PCM and go cable throttle.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
12200411 is the most common (01-02)
9354896 will also work (99-00)
__________________
www.speartech.com
www.speartech.com
Since I have the LS6 manifold and TB it just kinda makes sense at this point to sell the ls2 PCM and retrofit the F body harness/PCM into me set-up. If I was to go back to DBW I need an intake, TB and pedal assembly. To make what I have work it;s simply a matter of a different PCM.... I thought about DBW
Andrew,
If it was mine to do, I would keep the E-40 and get a LS2 intake and TB. You will make more power with the LS2 intake and the bigger TB. Making the LS1 ECM work with the LS2 can be done, but a custom harness needs to be made to adapt the LS1 ECM to the sensors on the LS2. Sensors are in different places, and in a lot of cases, use different plugs. I love the DBW setup on my LS2's. I'll bet that you end up coming out cheaper than converting to a LS1 ECM.
Regards, John McGraw
Andrew,
