truck intake clearance.....
when u mean mounts used......do you mean what kind of adapter plates you used with the motor mounts....i thought they all worked the same....factory motor mounts mount to the new adapter mounts.....
Yes the Adapter plates, Mount mounts and frame stands will all come into play if you want the Truck into and Alternator to fit under the hood with out any modifications..
Plates can be anywhere from 1/4" to 1/2" thick. There are Short/wide and Tall/narrow Engine mounts. Frame stands to match the engine mounts with different heights also.
There is a 7/16" different in the tall vs short mounts. So.. depending on the items and pan.. It will fit or not ! LOL.. I am using Tall/Narrow mount with modified short/wide frame mounts.. so, you can roll your own or even custom to get what height you want.
Good luck.
Good luck.
do you think you could post up the directions on how to make your own mounts.....my elcamino origanlly had a 350 in it.......will i need the 1in set back adapter plates or just the regular adapter plates....? sorry if you could post up your dimensions it would be great....
thanks for you help
thanks for you help
http://www.montecarloss.com/ls1montecarloss/
Its a Monte project, but lots of GREAT info. Lots of pics.
Yes, If you look at the BRP kit, you can either buy there kit or use it as a sample of how to fab up your own... I built my plates using the templates in the FAQ out of 1/4" steel plate. You just have to think it through and be creative, and that is what Hot Rodding is all about..! doing something yourself and doing it your way...
