13 pin connector on 4L60e? (TH400 swap)
Old 08-24-2009, 11:55 PM
demonpixel's Avatar
Default 13 pin connector on 4L60e? (TH400 swap)
I posted this in the transmission section also; haven't gotten a response in a few hours so I thought I'd try here.
Apparently there is a 13 pin connector that goes into the passenger side of a 4L60e:
Instead of a 4L60e, I put a TH400 behind my LS1. Is it ok to leave this 13 pin connector unplugged? I just don't want the computer to be confused.
Thanks for any help/advice
Old 08-25-2009, 12:17 AM
poconojoe's Avatar
Flash the PCM for a stick shift tune
Old 08-25-2009, 08:43 AM
demonpixel's Avatar
I had a feeling someone was going to say that. I had a custom mail-order tune done by Texas Speed & Performance and I mentioned all the specs/mods of my engine/drivetrain, so I'm pretty sure they should have tuned it for a stick shift, since I said I had a TH400. Crossin my fingers now.
Old 08-25-2009, 09:21 AM
MeanYellowZ's Avatar
yup, just leave it unplugged and cover it/ tie it out of the way. Are you going to use the VSS with the 400? This seems to help with decel issues and is used for emissions stuff if you are set up with them. For the record I have run a few without VSS without any real issues either.
Old 08-25-2009, 10:07 AM
demonpixel's Avatar
Yep, I got a VSS conversion kit (pigtail harness PN 12085498 , rotator wheel PN 8655315, and sensor PN 24232618), so I'm good there.
Old 12-19-2011, 04:01 PM
T-Pat's Avatar
Ive read a lot about this VSS swap, I know that it will work for the 400 but will this same setup/part numbers work for the TH350 as well as I am in the process of putting one in my SS as we speak? Thanks!
Old 12-19-2011, 05:58 PM
the_merv's Avatar
Ya just tie it out of the way. I use the ABS Wheel Sensor to run my speedo in the car..helps with the TH350.
Old 12-19-2011, 08:25 PM
LS1Tech Sponsor
psiconversion's Avatar
I use a 4L60E reluctor wheel and sensor in our LS2 TH350 setup.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 12-20-2011, 10:37 AM
jmd
jmd's Avatar
Post
output shaft is larger o.d. and higher spline count; the reluctor wheel doesn't fit and I'm pretty sure the sensor is different too. 4L60-E parts are what you want but won't fit the small speedo gear opening tailhousings, only big.
Quick Reply: 13 pin connector on 4L60e? (TH400 swap)
