DBW ECM / Cable TB
Old 08-29-2009, 08:23 AM
johnnywhale's Avatar
Default DBW ECM / Cable TB
I didn't want to hijack the pedal thread, but it got me thinking. I have a 2004/5 Silverado harness / ECM, but want to use a cable TB. Can this be done? Use a regular TP signal, not the pedal assembly?
Thanks,
Johnny
Old 08-29-2009, 08:53 AM
CalEditor's Avatar
YES
I would set it up with a calibration from a Express Van, but you could go about it the other way.
Old 08-29-2009, 10:03 AM
What do you mean? Does the Express use a pedal mounted TP and a cable throttle body? I can mount about any pedal.
Thanks for any advice.
Johnny
Old 08-29-2009, 10:26 AM
poconojoe's Avatar
Johnny
Most Express vans use a cable throttlebody, so they would have a drive by cable tune(OS) in them. If you want to convert from drive by wire to drive by cable, you need to run a DBC tune and make some wiring changes to your harness, if you are already setyp for DBW
Old 08-29-2009, 10:30 AM
Yes, I found schematics / connector views for non-TAC Express vans, and I dont have a tune yet, so I should be good! Thanks for the advice!
Johnny
Quick Reply: DBW ECM / Cable TB
