truck intake or stock f body
Old 08-29-2009, 04:03 PM
70cartruck's Avatar
Default truck intake or stock f body
i just recently purchased an 05 lq4 with 40k on it....i found a small hole in the intake where it looks like something damaged it when it was removed.....i have access to a whole set up of stock ls1 f body intake....fuel injectors and rails....should i stick with buyin another truck intake or run the factory f body.....i assume they have different power curves....? Or spring and buy an ls6 intake....are they really worth 400 bucks......?
thanks
Old 08-29-2009, 04:15 PM
bczee's Avatar
Yeah.. the Truck has much better low and mid range RPM and Power.. the LS1.. may just be better above 5500 rpm's.
But got with a LS6 if you can. That is the best bang for the buck!
Old 08-29-2009, 08:39 PM
Bo185's Avatar
If you swap to the car intake you have to do a few mods to the truck WP and accessories for it to work.
Might look for a TBSS LS2 90mm truck intake as well it will bolt in place. Be a nice upgrade and they are about as good as the LS6.
Its the SSR90mm one
http://performancetrucks.net/forums/...d.php?t=397720
Quick Reply: truck intake or stock f body
