HELP W/ 2004R-lq4 CARB LINE PRESSURE & KICKDOWN LINKAGE?
Old 08-30-2009, 05:02 PM
G'D_UPLQ4's Avatar
Exclamation HELP W/ 2004R-lq4 CARB LINE PRESSURE & KICKDOWN LINKAGE?
aNYONE HAVE ANY PART NUMBERS OR SUGGESTIONS FOR THIS ISSUE?
IM USING A 2004R BEHIND A CARBED LQ4. i WAS TOLD I NEED A BRACKET FOR THE CARB...SO IT WONT BURN UP THE 2004R
HELP!!!!!
Old 08-30-2009, 08:27 PM
S10xGN's Avatar
HELP!!!!!
For a Holley carb, use this one.... There are other brackets you'll need depending on which style cable you go with.
Old 08-30-2009, 08:51 PM
G'D_UPLQ4's Avatar
thanks S10 do you think you give me a quick run down on how and what this part does..and how the cable is set up and where everything should be bolted or mounted thank you imnot to experienced in this area
Old 08-31-2009, 04:48 AM
LS1MCSS's Avatar
Here is a link to a good article that you need to read. It will explain a lot about the throttle valve cable on a 200-4R and 700R4.
http://www.chevyhiperformance.com/te.../photo_07.html
Old 08-31-2009, 11:26 AM
G'D_UPLQ4's Avatar
thanks alot very helpful
Old 08-31-2009, 09:07 PM
S10xGN's Avatar
Before anyone can help you, you need to give specific info. What carb? What manifold? What TV cable? And you really need to buy a pressure gauge setup and check your trans pressures while adjusting the cable.
Old 08-31-2009, 11:06 PM
G'D_UPLQ4's Avatar
I'm going with a holley 750 mexhanical secondary, GMPP intake, I don't know what tv cable to choose of how to set it up from the trans to the carb. Thanks S10 any part numbers would be extremely helpful.... Also when I adjust the tv cable what readings should I see for the pressure
Old 09-01-2009, 10:51 AM
S10xGN's Avatar
You MUST use this bracket on the carb's throttle linkage, regardless which cable you end up with. If you elect to use a "stock type" kickdown cable, use this bracket. If you go with the Lokar setup, you'll want KD-2200RHT cable, and the SRK-4000 bracket to locate it. Be sure to enlarge the pic on the right side of that page!
The pressure gauge (300# gauge, 4 ft of #4 hose with a #4AN swivel end) installs to the DR side port about 6" above the shifter quadrant. I (permanently) installed a 45° 1/8" NPT x -4AN fitting with a -4AN cap when not in use. Pressure checking info can be found here.
Old 09-01-2009, 11:16 AM
G'D_UPLQ4's Avatar
so far S10 you've been the biggest help on LS1 tech ..alot of these guys dont know or give the wrong info....i really appreciate it...do u think u could give me some info on setting up the holley fuel pump
Old 09-02-2009, 03:11 PM
S10xGN's Avatar
Dude, go to any of the pump mfg's, they have all the info you need to get started. Try Barry Grant, Holley, Aeromotive, etc. and they'll all have downloadable diagrams and schematics.
Old 09-02-2009, 04:57 PM
G'D_UPLQ4's Avatar
thx S10 i looked at the lokar setup. If go with these do i still need both of the holley brackets or one of them.Also It shows two cables on the carb..a kickdown and throttle.....so do i need two different cables or just one. Also if there is a need for two what bracket do i use? thanks
Old 09-03-2009, 02:43 PM
S10xGN's Avatar
If you go Lokar, you'll need the Holley '121 bracket for the carb, the Lokar TV cable, Lokar throttle cable, and the Lokar mounting bracket (both cables fit into the bracket).
Attached Thumbnails HELP W/ 2004R-lq4  CARB LINE PRESSURE & KICKDOWN LINKAGE?-100_1015s.jpg
Old 09-03-2009, 09:04 PM
G'D_UPLQ4's Avatar
thanks man excellent help
Old 11-19-2009, 09:57 AM
G'D_UPLQ4's Avatar
what lengths do i need for the throttle and tv cables?
Old 11-19-2009, 07:58 PM
S10xGN's Avatar
They're both universal and need to be cut to fit...
Quick Reply: HELP W/ 2004R-lq4 CARB LINE PRESSURE & KICKDOWN LINKAGE?
