CSR Thermostat housing HELLLLLPPPP!
okay seriously cant find any good answers anywhere on what thermostat to use with my ls1 csr thermostat housing.
theres quite a few threads on here with people having the same problem but nobody seems to have a good solution yet.
i called csr and they rudely wanted to get off the phone but said i need a old school 350 thermostat thats 54mm
im wanting a 160 degree
ive used mr. gaskets, ac delco, and a super stant 160 thermostat... (old school 350's)
all dont fit
does anyone have a part number that fits in the housing??????
all dont fit
I picked up a standard 180 for a '70 Camaro 350 from Kragen. It will fit loose in the housing. The CSR guys told me it is supposed to be loose to let a small amount of coolant pass when the stat is closed. I have been using mine for 3+ years like that with no problem. In what way have the ones you have tried not fit?
Pat
Pat
Im working on his car and have used the CSR piece before but I think its redesigned now. The actual nipple for the radiator hose screws into the base now and i thought it was all one piece before. The themostats "top" or whatever you want to call it hits the inside of this nipple. I really thought the old ones were one piece deals. The redesign is not working with any of them so far.
I went with these guys. It uses an LS2 thermostat that even has the heater hose divider within the water pump.
http://www.synisterproducts.com/TH.htm
Hmm, i have one of the new 2 piece design ones, and am using a 160 degree standard AutoZone thermostat for a SBC 350. It doesn't fit loose like i was told it would, but there are no leaks and temps are staying under 180 so far.
I have the same issue.... I haven't got to completely test it out but I may have a solution. I bought one of the old school, what I would call fat bottomed stats they sell at the auto parts stores in the hot rod section (where the carbs and intake manifolds are). Mr Gasket #4363 Balanced Thermostat for GM/FORD/AMC. It doesn't fit perfect but if you dent in the three prongs on top it fits.
