wont stay running - wiring issue?
Old 09-14-2009, 04:07 AM
SirWarrior's Avatar
Default wont stay running - wiring issue?
FYI
2002 LS1 out of WS6/T56 going into 240sx
1-wire alternator - can that just go to the dummy light in the cluster, and no other place, right?
my vats should've been programed out,
but what would happen if it isn't?
cut power to fuel pump? would it cut spark?
would it be something I can see with OBD2 scanner?
Car starts, and dies within a second or two.
Going to be checking and rechecking all the connections tomorrow.
Old 09-14-2009, 05:32 AM
cutlass_455's Avatar
Can you put a fuel pressure gauge on it and see if the fuel pump is dying to cause it to stall?? Trouble light on the fuse for the FP?? If the pump is dying that sounds like a VATS thing I think, but you think its tuned out.
Do you got enough battery charge?? Try putting the charger on it while starting it, and make sure you got lots of grounds done up. Engine to battery, engine to frame, engine to body, battery to frame, some even say trans to frame/body. And your harness grounds too, there is a few of those.
Old 09-14-2009, 10:50 AM
ls1nova71's Avatar
Should have been, this is the key statement. I'd double check that. There's been many people on here have the same problem, and it's turned out to be VATS. It will do exactly what you described if it's not turned off.
Old 09-14-2009, 03:06 PM
SirWarrior's Avatar
well, just double checked the fuel pump relay
stays on when cranking and running, so that would suggest VATS is off
but it still won't stay running.
Again, that 1 wire on the alt plug, can that just go to the battery light in the cluster, no other place, right?
Old 09-14-2009, 07:31 PM
SirWarrior's Avatar
just checked pins
blue - 20 and 57 got constant
blue - has ign when on and when start
blue - 1 and 40 have grounds
red - 1 and 40 have grounds
Old 09-15-2009, 01:00 AM
SirWarrior's Avatar
pulled 3 codes with obd2 scanner i managed to borrow
p0650 mil control circuit malfunction
p0481 cooling fan 2 control circuit
p0480 cooling fan 1 control circuit
but the abslt tps reads 27% when tb is closed shut
and 84% at WOT
Old 09-15-2009, 08:14 AM
digitalsolo's Avatar
I've only ever seen 2 things cause that:
1. VATS
2. MAF
If the MAF has been eliminated in the tune incorrectly, it will cause exactly what you describe here. Obviously, VATS will also do that.
Old 09-15-2009, 04:50 PM
SirWarrior's Avatar
1. VATS
2. MAF
well, Vats cuts only fuel right?
I get nice 60psi of fuel at all times.
How would I go about troubleshooting if its a MAF issue?
I'm open to pretty much anything at this point
seems to me like its cutting spark and killing the engine.
what would cause that??
Old 09-19-2009, 12:02 AM
SirWarrior's Avatar
yep, turned out to be VATS
Speed Inc to the rescue
Apparently, when VATS cuts fuel, it cuts injectors, not fuel pump.
Thanks for clearing that up G-body.
It runs perfect now
Old 09-19-2009, 12:25 AM
Right on, good to hear.
Quick Reply: wont stay running - wiring issue?
