starter relay trigger
maybe somebody knows this one off the top of their mind..
im using a 2005 silv hd harness and underhood fuse block
what wire triggers the starter relay? ive read the pinouts but i dont have a diagram to follow so its not jumping out..just need to know where to hook the ignition switch.. thanks in advance..
its going into an 86 k5 blazer
yes i can bypass it very easily but im trying to use the underhood fuse block
since it has everything i need right there. i have a tpi engine in there and its time time to upgrade again
ill just get the alldata subscription..wiring is not a problem at all its just getting the diagram. figured that someone had done this already
