painless wiring - coolant temp, wire cut off
Old 09-19-2009, 08:49 AM
demonpixel's Avatar
Default painless wiring - coolant temp, wire cut off
Hey guys, I'm using a Painless Perf. wiring harness for a 98 LS1. The ECT has three wires on the connector, but one wire, the green wire, is cut. Anyone know the reason for this? Where does this wire go? It doesn't say in the Painless instructions.
Here's a pic of it:
Thanks for any help/advice. Am I ok to just connect it and not worry about that wire?
Old 09-19-2009, 09:09 AM
Marky522's Avatar
Alldata shows that wire going to the cluster, So you dont need it, unless you are using a matched gauge in your dash then you could wire it to that wire.
HTH
Mark
Old 09-19-2009, 09:40 AM
demonpixel's Avatar
HTH
Mark
Nope, I'm using aftermarket gauges. My water temp gauge goes to their sending unit that I put on the rear of the passenger side head. Thanks Mark!
Old 09-19-2009, 10:10 AM
Marky522's Avatar
Glad I could help.
Mark
