scrapping factory harness so I need advice.
Ok well im going carb. So I won't be needing any of the underdah wiring In my impala. So I would like to install a premade muti circuit harness. But I have a few questions. Like on my head and tail lights. How many circuits would that take up? Also I am interested in buying the circuit boss harness from painless. I will be running the head/tail lights, ignition, driverside window, electric fuel pump, stock fbody fans, an oil cooler. Or is there a better harness out there? I don't know crap about wiring and harnesses so bear with me. Thanks.
So your intent is to re wire the whole car ? is there anything wrong with the current body and under dash harness ?
Why not just leave it as is and just intergrade what is needed with a standalone engine harness ? You don't need to rewire a whole car just because you swap in a different engine !
But if that is what you want, it can be done... Contact Painless and talk to there tech on how many circuits are needed.
