Rear Differential Mystery?
Old 09-27-2009, 04:56 PM
Blue67LS2's Avatar
Default Rear Differential Mystery?
Gents,
I purchased a rear end which was supposedly removed from a 69 SS Camaro with multi-leafs. I know it is a 10 bolt and it looks to be a GM, however upon further investigation I am pretty sure its not a first gen Camaro rear as none of the casting or axle code match up. I am trying to determine what this thing is in order to confirm the dimensions and axle ratio, but I cannot find anything that matches up?
The passenger side axle housing has the numbers 2FB0124 and the casting number is 555771. I have spent several hours looking on the web, but can't find anything that tells me what this thing is... so if there are any "rear end" experts out there I would greatly appreciate any help in solving this mystery.
Thanks in advance for any help!
Attached Thumbnails Rear Differential Mystery?-dsc01891.jpg   Rear Differential Mystery?-dsc01046.jpg
Old 09-27-2009, 05:09 PM
69Project's Avatar
Go to Team Camaro.org and go to the drive train section and ask for Big Gear Head to look at your numbers.
Old 09-27-2009, 07:43 PM
Bowtie70SS's Avatar
Need a pic of the cover. Kind of looks like a 8.5 but could be a 8.2. If it is a 8.5 then it won't fit they did not start using 8.5 rear ends until 1970.
Quick Reply: Rear Differential Mystery?
