Transmission kickdown for th350?
How are you guys hooking up the transmission kickdown for the th350 and 400's......
This is going in a 1970 el camino....factory th350.....didnt know if someone knew of a way to use some kind of factory bracket.....?
Using a lq4 that has been converted to cable throttle and have a factory f body intake.....?
Thanks
Also what is the proper part number for the corvette fuel filter regulator.....? Does it have a place for the return fuel also...?
Thanks
Get in touch with Lokar or Bow Tie Overdrives for a longer, adjustable kickdown cable. I believe Bow Tie Overdrives has a kit for the LS engines.
Wix #33737 for the filter. $34 at rockatuto.com, and not too much more at the local parts house. I has a 3/8" inlet and outlet, and a 5/16" return.
