4L80E driveshaft needed
Old 10-06-2009, 09:50 AM
bustac's Avatar
Default 4L80E driveshaft needed
I'm in the middle of swapping my 1989 Silverado SWB to a 2000 5.3 4L80E. Anyone know which driveshafts can be used. My trans has a yoke for a ujoint on the end so I'm assuming I need something with ujoints on both ends.
Any likely donor vehicles? Someone mentioned Express Vans?
Old 10-06-2009, 11:54 AM
chevellepowered's Avatar
th400 yoke will slide into trans,, there the same..
Old 10-12-2009, 10:35 AM
bustac's Avatar
Default driveshaft
So the only difference is the turbo 400 end is a slip splined end and on my 2wd 4L80E the yoke is bolted in?
Old 10-12-2009, 08:43 PM
Shon Herron's Avatar
make sure you get the RIGHT Th400 yoke.
this is the yoke to reference for dimensions needed
Neapco N3R-3-9161X yoke
You may not be able to find that particular yoke except on the net for order but many places make a yoke, just need to look up the part number and get the dimensions.
I can not stress this enough. I some how got a Th400 yoke that is rare and has caused me alot of headache. The OD was not correct.
Old 10-13-2009, 09:27 AM
73 nova guy's Avatar
4l80 used both bolt in and slip in.. i belive if they had a carrier they were bolt in
Quick Reply: 4L80E driveshaft needed
