oil pan kit
Old 10-12-2009, 09:35 PM
crosstraining's Avatar
Default oil pan kit
Has any one used this oil pan kit? Do I need any other parts?
"SDPC chevrolet offers a kit with oil pan, gasket, indicator tube and indicator, pickup tube and crankshaft oil deflector. PN 19212593 and its 145$ plus shipping"
Old 10-12-2009, 10:44 PM
Smo's04Gto's Avatar
Think thats the LH8 hummer pan.Hangs kind of low about 2" below the frame in my 72 nova. Do a search lots of info.
Old 10-13-2009, 12:35 AM
gofastwclass's Avatar
Not sure about the Hummer thing, the pics I have seen aren't what I own.
I've used that pan kit and it works great. That is what is referenced as the "Muscle Car Oil Pan Kit" in the GMPP catalog and it is basically a Gen III version of the time honored old school small block pan. You don't need to buy anything else except an oil filter, the engine to sit on it and some oil to fill it. It even comes with a new gasket and bolts.
BTW - the oil filter you need for that pan is the same part as a 2007 6.0 Silverado HD.
This pan isn't as short as the fabled "Camaro" pan but isn't extra feet deep like the truck pan either. It's somewhere in the middle about 1.5" or 2" shorter than the truck unit. I measured the thing before I put it on but I can't find the pics with the ruler in front of it. The shallow slope is longer front to back than the Camaro unit which may save you having to cut it like many people did with the Camaro pans on older swaps.
Old 10-13-2009, 01:31 PM
Thanks for the responses
Old 10-13-2009, 01:40 PM
performinnorman's Avatar
Is that the same as the 5.3 H3 pan that many use for 2wd S10 LSx conversions?
If so, I need one too.
Never mind. I figured it out.
Old 10-13-2009, 08:34 PM
key4's Avatar
Do you guys know if this oil pan will work on the mustang swap? Its alot cheaper than the fbody oil pan which is kinda hard to find.
thanks
