67 Chevelle 5.3 finally runs
Thanks to everyone sharing info here my 67 Chevelle 5.3 restomod finally runs. Working on getting wiring done then finish assembly of the car.
http://www.youtube.com/watch?v=UjmfD0bi2bI
Malcolm
Malcolm
Looks and sounds great, congrats!
What transmission are you running? Who did you use for wiring and tuning? Also, what exhaust manifolds are those? It looks sweet, again congrats!
clean!!!!!!!!!
those are the truck headers right,, howed u get them to fit, that is an a-body right.. i ran them on my 70 chevelle had to grind them up. . real tight fit.. ,
awsome build
awsome build
Thanks everyone, it's been a long wait to get everything far enough along to hear it run, about 5 years. Could not have done it without the help from everyone here.
It's a 5.3 w/4l60e pullout from 2003 Tahoe rollover.
The manifolds are the originals with the bosses for the heat shields smoothed.
The pass. side worked , the driver side had to relocate flange to miss frame.
There's a pic of the rt. manifold on page 3 of my showroom at chevelles.com
(link in my sig.)
I reworked the original harness, used current perf. conversion fuse box,
PCM by wait4me.
Rob I didn't know you were driving, last update I saw you were wiring.
Thanks again
Malcolm
(link in my sig.)
PCM by wait4me.
Thanks again
Malcolm
Malcom,
5 years? that is a long time. I have been driving for a few weeks now. Now to work out bugs and make the car look good.
What are you going to do for cooling fans? Did wait4me disable HVAC recirc door and enable fan #2 control for you? There is some mis-information on this site and others saying you can't control 2 fans with a truck PCM. EFILive has the switch in their software. HPTuners doesn't, but they will enable fan #2 control if you send them your tune. They did it for me and it works perfectly. I assume the switch will make it into a future release.
Rob
Rob
Rob I'm using a '98 Mustang fan left over from building a wrecked Mustang
for my sons first ride.
It fit the '88 Corvette rad perfectly, I trimmed the mounting tabs and mounted it from my rad brackets.
Wait4me said they could program for fan outputs, I have'nt got my fan wired up
yet to try to see if it works.
Malcolm
Nice I just had my 67 Chevelle running too trying to work out some bug too. should be going to the exhaust shop this Friday. have fun . I use Fuelinjection Connection Harness. It"s pretty Cheap compare to S & P cost half and it come with 2 fan relay for running 2 fan
67MAL,
what did you coat the exhaust manifolds with? Looks great !
