Cant get ASP relocation idler bracket to fit?
Old 10-25-2009, 12:13 PM
70cartruck's Avatar
Default Cant get ASP relocation idler bracket to fit?
i purchased the idler relocation bracket from action speed parts.......the bolt that is closest to the throttle body (going into the head) will not fit due to the tps sensor in the way....? (the entire bracket will not fit) I thought you were supposed to be able to use a f body intake with this setup....can you not use a f body throttle body like i am...do you still have to use a truck throttle body.....? im obviously still using all the truck accessories.....
Someone please chime in.......im trying to get this project done
