93 3.4 Camaro A4 to LS1 A4 swap wiring NEED HELP
I swapped a 2000 LS1 and harness into my 93 v6 camaro. Everything is complete except for the wiring and I am stuck. The original harness had three plugs that went into the computer, one plug that plugs together on the pass wheelwell (I think it goes to the fuse box), and the blue and white connectors that go to the dash harness. I don't have any of the three small plugs on the ls1 harness. I have pin outs for the Ls1 harness and have removed the wires I didn't need already from the pcm connectors. I need the pin outs for the under dash harness plugs (white and blue). The ls1 harness has the same plugs but the pins and wires are different. Also do the three small connectors on the engine side connect toto the small connector on the wheel well? If anyone can be of help it would be much appreciate it. Thanks in advance, Jason.
hey, i am doing the same engine swap. i have a 95 firebird with a 3.4 i am swapping to a 98 5.7 ls1. i need the kick panel pin out. the 3.4 had four plug that goes through the fire wall. two blacks a white and a blue. my 98 harness has three. a blue and two whites. it is missing the two blacks. if you could forward me the pin out info, it would be greatly appreciated. thanks Paul.
