ECU and Harness from Truck
I dont know exactly what the ecu is from( may be stock) but its in a 99 Chevy Truck. The truck has a F1C Procharged 408 and the guy is gettin ready to go to Big Stuff III. Will there be any problem with this working on my 2004 LS1??
LS1Tech Sponsor
The 99 harness will not have the grounds for the O2 heater circuits or some other grounds required by your 04 PCM. As Pocono said, the 99 has red retainers instead of the green ones your 04 PCM needs, they wont fit either since they are keyed differently. Regardless, if the PCM and harness match (whether 99 or 04), they will work with the 04 engine albiet if you change the FI connectors.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
