C6 cluster into firstgen w/LS7
Old 11-29-2009, 01:49 PM
Gandalf's Avatar
Default C6 cluster into firstgen w/LS7
I have an LS7 in a '69 Camaro with a 5-wire hook-up harness and stock (reprogrammed) ECU. I'm wondering what it will take (wiring) to fit an instrument cluster from a C6 vette? What do I need to make this work besides the fabrication?
Any help appreciated,
G
Old 11-30-2009, 02:17 AM
rsz288's Avatar
G
If you can get hold of the correct connectors, then it all has a good chance of working. Tacho, speedo, oil temp hard wire via the connector/s. As does the lighting stuff. Anything else mostly goes via the CAN from the ECM. Like fuel/temp DIC info.
