LS1 swap into 96 3.8
I was wondering if anyone on here has done an LS1 swap into a 93-97 car. The car I currently have is a 96 3.8v6. Late spring I plan on buying a salvage donor car so that I'll have all the necessary parts. Just wanted to know of any problems you ran into and how you overcame them. I tried searching but no luck, I'm not really good with the search. Please don't try to discourage, mind is already made up. I'm not trying to sound like a dick but to many people saying its a waste of time/money. The thing that has me the most concerned is the wiring. Thanks. If I have missed something please chime in.
Things I know that need replacing:
-Complete Engine w/ harness and PCM
-K-member (will be dropped out bottom of donor car with engine and trans connected)
-Trans(6spd)
-clutch
-clutch hydraulics maybe? (will the ones from the V6 work? They are brand new)
-fuel lines
-fuel pump
-radiator
-radiator hoses
-throttle cable
-front springs (already did rears)
-exhaust
-want to do gauge cluster (not sure on wiring for it since its digital mileage)
-Upgrading to the LS1 brakes (want to)
-Rear drum to disc (want to)
-Trans(6spd)
-clutch
-fuel lines
-fuel pump
-radiator
-radiator hoses
-throttle cable
-exhaust
Thanks, but I am going to pick up a whole car so it will already have it. The swap is about 5-6 months away, but I will post pics with the build. Thanks all for the information.
hope everything goes well. i'm looking to do a v8 and t56 swap too, sometime next year. I have a 97 camaro 3.8 m5. you switch your rearend gearing already, are you using the factory rearend or aftermarket?
'Bird Director
I gave it a shot with the LT1/V6 steering rack mounted on an LS1 K-Member & LS1 Steering linkage. Not only was the linkage in the way of the exhaust, it also hit the driver's side engine mount perch.
Ya its around that price but if u can do it urself, then do it. I just don't know wireing so i had mine sent off. Good luck with the build!!! I am having a lot of fun with my build. Been running now for couple months and i think that it was money well spent. If people say otherwise, all i have to say to them is that i still have the car i went to high school with and got my first virgin in the back seat! Hahaha. have fun man and good luck!
