rx7 7.0l v8 twin turbo build
Old 12-19-2009, 05:05 AM
tinker-27's Avatar
Default rx7 7.0l v8 twin turbo build
hi guys made a bit of progress over the last few weeks here are some pics,
spec are
7.0l
all steel internals,
cnc flowed after market heads,
two gt35 turbos
emerald new type ecu with turbo control,(and traction i hope !!)
will post some more as stuff when i get time to do more
Old 12-19-2009, 05:17 AM
06 6.0 GTO's Avatar
holy ****.
Good call on needing traction control lol
This is just sheer awesomeness
Old 12-19-2009, 10:08 AM
600HPShark's Avatar
Nice setup. Love the brakes.
Better add new underwear to your list.
Old 12-19-2009, 10:25 AM
tinker-27's Avatar
its already got a viper diff and uprated box so will see what will break next ?
Old 12-19-2009, 10:39 AM
sciff5's Avatar
Does it have billet or broached hubs for larger outer stub shafts and 300m mid bars? If not the diff may be strong but your still running on pretty much stock half shafts which could be an issue if it starts wheelhopping.
Regardless though I would like to hear more about the setup I am planning on custom mounting a viper diff in my FC once I start breaking the stock rear end.
Old 12-20-2009, 07:51 AM
tinker-27's Avatar
Default viper rear end
hi it has custom 300m drive shafts in it so i think the cvs will be the weak spot but time will tell,
Old 12-21-2009, 10:35 AM
gjohnson's Avatar
Dude, you've got a couple of typeo's in the post. You keep referring to the displacement as a 7.0L and I know that can't be right. You would have to be insane!!!!!!
Old 12-21-2009, 02:39 PM
digitalsolo's Avatar
Looks good, very similar turbo placement to the TT FD I've been working on. Merging the downpipes?
Old 12-23-2009, 09:01 PM
03 snake's Avatar
Subscribing. Beautiful job on the welding. Look forward to the updates.
Old 12-24-2009, 04:45 PM
JarrettL's Avatar
That's just a 427. Yes it's big but it's done all the time.
Old 12-24-2009, 10:42 PM
DiscerningZ32's Avatar
I can't tell if it's an FD or an FC.
Engine bay looks to be an FC but not sure.
Looks like it's going to be badass either way.
Old 12-25-2009, 12:27 AM
That's definitely an FD.
Old 12-26-2009, 12:46 PM
TTLS1GP's Avatar
Yessir!
Old 12-29-2009, 03:46 AM
gnx7's Avatar
did you resleeve the motor? If not that won't handle much boost safely.
Looks like a wicked project and those turbos should instaspool!
Can you post up some pics of the Viper rear end setup? Those are very stout indeed.
Old 12-29-2009, 04:40 AM
jomomma's Avatar
what headers are those?
Old 01-05-2010, 04:24 AM
tinker-27's Avatar
hi guys a couple of updates,(will post some more pics soon),i am about to build the motor for it but i am de stroking it from 4.125 down to 4.00" to allow for better pistons, et performance 255cc heads,238,238.598cam,fast 90 intake,twin gt35s,all headers and exhaust made by myself,twin plate clutch,emerald ecu with 3 maps,and boost control against throttle angle and revs,oh and traction control !!
Old 01-05-2010, 04:52 PM
gnx7's Avatar
Can you provide a link to the Emerald ECU with 3 maps? Keep up the good work.
Old 01-05-2010, 05:42 PM
tinker-27's Avatar
Default !
http://www.emeraldm3d.com/
this is there web site but not much info on it at the moment,i ambuilding the guys who own emerald another rx7 twin turbo (doing it at the same time as mine), i have used there ecus for years on ls motors,and they are working on one which will do more boost control,they are very simple to use and do everything you need, if you want any more info you can ask them or i will find out for you, cheers craig
Old 01-05-2010, 05:47 PM
NemeSS's Avatar
impressive!
its gonna be scary good
Old 06-11-2011, 02:01 AM
navi243's Avatar
updates?
Quick Reply: rx7 7.0l v8 twin turbo build
