Anybody using plastic/Aluminum radiators in A-bodies?
I'm working on installing an '04 LQ9 in a '69 Pontiac LeMans, and I'm considering different options for radiators. Looking at most of the LSX swap threads it appears that most people went with 2 or 3-row all aluminum radiators, but I was wondering if anyone has tried a newer (less expensive) plastic tank/aluminum setup. Spectra premium (through Rock Auto) offers a Plastic/Aluminum setup (sized for my vehicle) for ~ 210.00, which is much less than most all-aluminum setups. It's a two-row "heavy duty" cooling unit. In comparison to, for example, the 4th gen camaro or even c5 corvette radiators (comparison LS1 factory one row plastic tank units) i think that this may be a better solution than some of the factory LSX setups.
I just haven't heard of anyone using one. Has anyone used/heard of one being used in an original A-body LSX swap? Am I missing anything?
Any thoughts?
Thanks!
Any thoughts?
Thanks!
sawzall wielding director
I am using a plastic/aluminum radiator in my 85 el camino. It was a 85 el camino autozone replacement rad. Works about the same as the copper old one or an all aluminum one. The all aluminum one may have a slight advantage because the side tanks will radiate heat better than plastic, but IMHO if you are that close to overheating anyway you need more airflow, a bigger radiator or both. The aluminum side tanks would be slightly more impact resistant too if that matters.
