stock mustang shifter with th400???
This should be easy if you get B&M's shifter installation kit. It includes a shift arm for the shift input into the trans, that'll let you get the cable attachment the necessary distance from the centerline of that tiny shaft. Adjust it closer and farther until the gates of the shifter match up with the detents in the TH400.
