DBW / TAC wiring questons
Hey guys,
I'm converting my 04 5.3 harness to a standalone and had a question.
I had some extra wires that goes into the plug that attaches to the tac module. These were orginally in the C100 connector so they wouldn't went anywhere anyways.
It was a Dk Blue, LT Blue, Gray, and Gray w/blk stripe.
Is it safe to remove them out of the tac module connector w/o hurting anything or affecting operation of the throttle body?
Hey while I got you here, do you know if the P/N plugs for the park neutral switch on the 4L60e tranny were a stand alone harness?
I need to figure this part out and can't find the plugs to go into my switch.....I'm curious if I need this anyways since my car already has a stock P/N switch in the console.
I didn't know if the transmission mounted switch controlled any PCM functions.
I don't know how the switch works within the PCM but mine had 2 plugs. The first all the wires went to the PCM, the others' wires went to the dash. I eliminated the plug going to the dash and kept the one going to the PCM. When I had it unplugged I also had the brake / TCC switch unplugged by accident and the car drove weird. I fixed the wiring / switch for the brake / TCC input and plugged in that harness at the same time which fixed my problem so I don't know if you really NEED it or not.
Thanks, shortly after this post I was doing some heavy googling and found out that they were cruise wires...Thanks again
