which clutch for LS1 swap in a Honda S2000
Old 01-10-2010, 07:02 PM
xyster's Avatar
Default which clutch for LS1 swap in a Honda S2000
I have a 2000 LS1 in my Honda S2000 which clutch should I go with when I pull the motor to do the painting of the engine bay and car? The motor is stock and will stay that way most likely, should I do a GM LS6 flywheel,clutch,bearing and new slave. I would like to keep the cost around 300-400 if possible.
Old 01-10-2010, 08:20 PM
aixgelo78's Avatar
still being new here....I have read a lot of threads raving about the ls6 clutch for a mild set-up...
Old 01-11-2010, 08:38 PM
xyster's Avatar
Thanks I was looking into that as 1 option, anybody else have .02 worth?
Old 01-12-2010, 05:40 AM
Pop N Wood's Avatar
For that money you can buy an LS7 clutch and flywiheel straight from your GM dealer. They are designed to hold 100 more HP than the LS6
Old 01-12-2010, 06:16 AM
the_merv's Avatar
LS7 setup from the WS6Store..
Old 01-12-2010, 07:22 AM
aixgelo78's Avatar
also to consider.....LS2/7 flywheels are heavier than ls6 units.... I dont recal by how much tho.....
Old 01-15-2010, 10:14 PM
Civette's Avatar
i run a c6 z06 setup for the price....i usually find entire setups for $250 with less than $5000 miles on them...
Quick Reply: which clutch for LS1 swap in a Honda S2000
