any newer swaps using the MSD EFI module?
Old 01-11-2010, 04:23 PM
drivelikeIstoleit's Avatar
Default any newer swaps using the MSD EFI module?
i was looking at a thirdgen site earlier about swap parts and this came up along with the MSD 6010 controller. I know the 6010 allows the use of a carb as it controls the coils for ignition. the MSD EFI module is described as being able to run all of the fuel injection in conjuction with the 6010. does that mean that a custom harness wouldnt be needed to run the efi if used in a swap? im just looking for clarity on its exact intended use or anyone using the module and 6010 with a swap already.
Old 01-12-2010, 08:42 PM
S10xGN's Avatar
You can use it with the factory ECM using this harness...
Quick Reply: any newer swaps using the MSD EFI module?
