67 Nova
Old 01-13-2010, 04:33 PM
JIMB's Avatar
Default 67 Nova
Has anyone installed a LS/ T56 or TKO 600 in a 67 Nova. Using a Heidt front end kit? Large hole in the tunnel. Any where close to working with a SS console?
Thanks
Old 01-13-2010, 04:52 PM
Joe Nova's Avatar
No the t-56 mounts farther back from the factory console. I don't know if anyone has moved their console back to match the opening.
Old 01-13-2010, 05:30 PM
ChrisBorsheim's Avatar
Isn't there an adapter plate that moves the shifting point forward on the T56?
Old 01-15-2010, 11:24 AM
itslow's Avatar
You will need to modify the tunnel. See photo.
http://farm3.static.flickr.com/2709/...ea65f311_b.jpg
I have the transmission mounted to the stock crossmember and am using the rearmost shifter location on the TKO. Car will not have a console. I believe that you could use the TKO and an offset shift lever with the stock console and a little work.
