Single Turbo LS1 Notch Build *videos* - Page 24 - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 10-06-2012, 11:41 PM   #461
bad6as's Avatar
High temp coated the hot side parts before I wrap them
And I came up with the crazy idea of taking my 2 step harness and building it in to the engine harness so I don't have extra connectors at the coils and a lot less wire running from inside the car to out side. Sooooo I figured what not do the meth and boost controler too. So I'm gonna combine it all as one and relocate some things to add to the overall apperance and get that clean look. What am I thinking
bad6as is offline   Reply With Quote
Old 10-14-2012, 12:20 AM   #462
Bloodbath's Avatar
Quote:
Originally Posted by bad6as View Post
I can't put my iat sensor in the charge pipe because the 2nd meth nozzle is right be for the coupler so I thought about puting it in the center of the manifold underneith it. Thoughts?
i wouldn't put it in the middle of manifold, my mate had his in one of those spots on the pro flow between the runners,and the sesnor was getting alot of heat soak, he changed it to just after the throttlle body blade with good reading results! meth injection only 383 ls combo.
Bloodbath is offline   Reply With Quote
Old 10-14-2012, 11:31 AM   #463
bad6as's Avatar
Well I got my manifolds, merge and down pipe wraped. Got the fan mounted on the radiator and got it all back on the car. For the iat I just ended up putting it where the hole is for the map. Just drilled and tapped it. And then cleared the intake to help it keep its color.
Old 10-14-2012, 11:33 AM   #464
bad6as's Avatar
I all ready had the iat in that spot blood be for you posted. =/ I guess well see how it works
Old 10-21-2012, 02:43 PM   #465
bad6as's Avatar
Note to self, new belt part number. Dayco 5060540
Old 10-21-2012, 05:57 PM   #466
Bloodbath's Avatar
you should be ok there dude, he had his deep in the manifold before he moved it.
now its just behind throttle body!
so how long till ya cruzing around? would like to here some results!
Old 10-21-2012, 08:44 PM   #467
bad6as's Avatar
I under estimated how much time doing all this work to the harness really takes, and by the time I get home from work I only have a few hours to work on it. But I'm making progress. I ended up cutting the harness in 1/2 aprox 16" after the pcm. And I'm re routing, shorting some make some longer and trying to hide it all. But it all comes down to time.
Old 12-06-2012, 11:16 AM   #468
nice build... Im located in maryland too. Im doing a 94 impala with a lq4 single mount turbo
dirty94SS is offline   Reply With Quote
Old 01-27-2013, 10:52 PM   #469
bad6as's Avatar
I made some good progress its just too hard to post pictures and such from my phone.
But..
I want to log my wideband and I know you can do it threw the egr or the a/c. Well my pcm is a 02 so it dosent have egr. So would I need to log it threw the a/c or can I still use the egr pin?
Old 01-28-2013, 05:51 AM   #470
Nice build man!
TDMKR496 is offline   Reply With Quote
Old 03-09-2013, 09:39 PM   #471
Great build man!!
Old 03-10-2013, 10:55 AM   #472
bad6as's Avatar
Thanks, I've been working on it a decent amount over the last month or so. I hope to hear it run again in the next few weeks. Now that the weather is getting nicer and the sun stays up longer I should be able to get a couple hours in a day.
Old 04-15-2013, 07:46 PM   #473
bad6as's Avatar
radio panel i made
new trans cooler and mount
radiator puke tank
aerocatch hood pins
-12 feeds the 4303 fuel pump now, also new mounting bracket for the pump and bigger filter
the boost leash II wants to monitor the c02 pressure so i drilled and tapped the top of the waste gate. i also sent the boost leash II in for a update to include his pulsh leash
changed the location of the fuel regulator and the way the feed and return lines run.
new lower radiator hose
lokar throttle cable and custom bracket
new kill switch and moved in the trunk so it was not on the rear bumper any more, wont get rained on any more.
drivers side exhaust support and fender support. passanger side has a fender support too
new alkycontrol pump bracket
lower hose clamps double as mounts for the braided trans lines
new jegs battery hold down
manifold pressure pass threw
horn and volvo fan controler for taurs fan. pcm will now control the fan
taurs fan on griffin 31x19x3 radiator
how she sits as of now.
Old 04-15-2013, 09:08 PM   #474
bad6as's Avatar
btw selling the 231/231 117+3 comp cam its on lsl lobes. $250 im going to have lil john or martin spec one for the new turbo and intake
Old 04-22-2013, 11:20 PM   #475
bad6as's Avatar
No one interested in the cam?
Old 04-23-2013, 07:35 AM   #476
Possibly. I have a stock LQ4 with an LS6 intake and planning on an S375. That's about what that cam is good for, right?
BTW been following this for a long time. Keep up the great work.
Hoopty5.0 is offline   Reply With Quote
Old 04-23-2013, 01:22 PM   #477
tired2valve's Avatar
all being done in a apartment complex.. high five!
its amazing seeing build threads like these.
tired2valve is offline   Reply With Quote
Old 04-23-2013, 10:20 PM   #478
bad6as's Avatar
Thanks, and yeah it was on a s380 and i went 151 mph with it. Nice lope, quick spool. Maybe martin at tick or lil john might read this and be able to set you in the right direction. Hke speced it for me with street car in mind.
Old 04-26-2013, 12:04 AM   #479
Big_Shannon's Avatar
I have been following your build. I have a LS fox motor plated and recently sold my meziere pump. I am going back to a stock style pump. My truck pump will not work unless I mill it. What pump did you end up using. BTW nice car!
Big_Shannon is offline   Reply With Quote
Old 04-26-2013, 03:10 PM   #480
bad6as's Avatar
Used a fbody pump, but i took the thickness of the motor plate off the tensioner and alt bracket
Related Topics
Thread Thread Starter Forum Replies Last Post
88 notch LM7 S480 Build EMP Forced Induction 29 12-01-2015 06:50 PM
67 Nova SS. Pro Touring. LS + Twin 72's. 1000rwhp plz. Anchor Forced Induction 76 01-03-2014 10:11 AM
New Owner here from Mass/NH xbladr Cadillac CTS-V 2004-2007 (Gen I) 22 12-05-2011 06:47 AM
** Bsaint - Estoril M3 LS1 Car Build (Start to Finish) ** Bsaint Conversions & Hybrids 13 04-22-2011 02:55 AM
Finally ported my intake and TB. ss1129 Gen 5 Camaro External Bolt-On Tech 9 03-18-2011 10:22 AM
Tags
1500, 408, body, build, chevy, fox, ls, ls1, lsx, model, motor, silverado, single, trans, turbo, vigls3088
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
